SPEAKER IMPEDENCE CALCULATOR
Several other companies do higher wattage g12h30-type speakers. How close they are, I dunno- and a lot are just bang-on 50 watts, so depending on how conservatively rated they are (or not), you might still be in trouble. I thought my Tayden Great Brit was much closer to my 55hz heritage g12h30s than the classic lead, for example. It is just bang-on 50 watts, though, and it can be a little fizzy on its own (I like fizz, but I suspect I might be the exception ) ).
But the CL80 would work at a pinch, as ICBM says. Just depends on how close you want to get.
thomann do a carvin 1x12 with a vintage 30 in it. It was 120 Euros which seemed pretty cheap to me.
Edit - oh they don't stock carvin any more, sorry.
But yeah the creamback would likely be the safest option, from the point of view it probably sounds closest to a g12h30 (?) and we know they're pretty conservatively rated. Plus you have an extra ~25W to spare even if it's not rated that conservatively.
Yep that's the one. And yeah it doesn't matter, 15 is close enough as far as I'm aware (hopefully ICBM can confirm). On the celestion site it says 16 ohms, anyway. I think they just copied the heritage specs, which are 15 ohms. But yeah it doesn't matter either way, as far as I'm aware.
