Yes, perfectly in order.
FYI if you try this with most of the Blackstar range you must put a dummy plug in the input jack to defeat the auto standby feature. A 1/4" headphone adapter works a treat.
Dave.
I have found this to sound awful in the past, the pre amp section is there for a reason, I expect the drive pedals straight into the fx return to sound horribly fizzy and nasty. However, as a 'sound' it could be something you want for an effect, but it won't damage your amp.
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
You learn such a lot hereabouts.
Cheers.
There's things I've had, there's things I wanna have"
I'm tempted to get a Matrix GT1000FX power amp at some point to go with my Amptweaker.
