Am I a philistine ? (Marshall-related)
TimmyOTimmyO Frets: 7614
edited June 2016 in Amps
Spent a rare afternoon able to noodle and play with the gear. My conclusion is this:
I prefer the JCM800 clean Lo with pedals to the Hi input (boosted or un-boosted) :-/
This was not the plan. The plan was to be a rawk cool dude ya know \m/
But no - more balls the other way. Go figure.
The most awesome sound of all was Guitar (either DGT or LP) -> Guv'nor -> Peacekeeper -> Klone -> a bit of plate reverb in the loop.
Red ones are better.
  • Flanging_FredFlanging_Fred Frets: 3110
    Nope, not a philistine at all. I do the same thing, plug pedals into the low input and I used a mk 1 Guv'nor too. Sounds great and far more flexible than just plugging in to the hi input (as good as that sounds for rock stuff).
  • octatonicoctatonic Frets: 33868
    Were you at bedroom or gig levels?
  • photekphotek Frets: 1470
    That's how I ran mine as well, with a DGT oddly enough. Box of Rock into low input sounded stunning.
  • TimmyOTimmyO Frets: 7614
    Master on 8, then Torpedo Reload dumping it back down to loud bedroom level
  • fretmeisterfretmeister Frets: 24712
    I'm very happy with my Helix, but that idea still makes my trouser dept move a bit.
  • SidNewtonSidNewton Frets: 660
    When I had my 2204 I used the low input with pedals. I used it in conjunction with a Gigrig loopy 2 with an OCD and a Keeley modded DS1 in one loop for crunch rhythm and a Tubescreamer plus delay in the other for lead. I could select clean, rhythm or lead by stepping on only one switch at a time, no tap dancing.
    Very versatile set up.
  • Modulus_AmpsModulus_Amps Frets: 2603
    I like the JCM800 lo input too, though I normally add a switch to change the cathode resistor on the 1st stage (2cnd stage on the high gain channel) so you get more JTM type tones, bit more gain, tighter bass and less compression.
    Love that circuit so much you can do with it, but it sounds great stock too
  • ICBMICBM Frets: 72801
    I prefer the high input, but I won't deny the low one is a great and very often overlooked sound.
