Lazy J advice please
DominicDominic Frets: 16161
Extension cabs ........are the 2 inputs next to the existing amp to speaker jack for extension cabs or foot controls
I am naive about ohm rating ......the speaker in the combo is 8 ohm right........what ohm should the extension cab speaker be ?
Do you have to disable/unplug the combo speaker if using an extension cab
I have a twin 12" cab with 2 Eminence Alnico speakers in it that has a 16 and 8 input ......how would I use this in conjunction with J20 ?
  • IvisonGuitarsIvisonGuitars Frets: 6841
    Those are outputs, DO NOT plug any footswitches into them! The foot switch for reverb and or trem should be hard wired in already.
    Your extension cab needs to be 8ohm and you plug it in along side the internal speaker jack, no need to unplug the internal speaker.
    http://www.ivisonguitars.com
    (formerly miserneil)
  • DominicDominic Frets: 16161
    thanks Neil......why are there 2 outputs - does it matter which one you use ?
  • MkjackaryMkjackary Frets: 776
    So that you can have 2 speaker cabs, no it doesn't matter which one you use as long as you make sure to match ohms
    I'm not a McDonalds burger. It is MkJackary, not Mc'Jackary... It's Em Kay Jackary. Mkay?
  • hotpickupshotpickups Frets: 1822
    2 outputs are for 2 speakers. One should alredy been taken up by the on board speaker of the combo?
    Get an extent cab if you can. It's definitely worth it ;)
    No there are 2 outputs in addition to the combo speaker
    thanks all concerned for the advice
    Really? I've only ever seen one
    Dominic;1099843" said:
    No there are 2 outputs in addition to the combo speakerthanks all concerned for the advice
    No ,2 ,to be sure..........thats why I was quite baffled
  • GassageGassage Frets: 30949
    @dominic
    Is that my original LJ?
    If so, the other hole is for a toggle that jesse fitted for a universal transformer, i think.
    Thanks James - that clears that one up then ......
  • fretfinderfretfinder Frets: 5073
    edited June 2016
    I believe that if you use both outputs (both should be into 8ohms cabs or speakers) then the amp will be putting out 4 ohms ie slightly quieter than its normal 8 ohms output. You could just use one output into the 2x12 8 ohm cab for the full monty. Although whether the difference in volume or tone is noticeable when the amp is putting out 4 as opposed to 8 ohms, I've no idea!
  • RigsbyRigsby Frets: 62
    edited June 2016
    From the Lazy J manual .......SPEAKER JACKS:
    The speaker is connected by a ¼” plug, located on
    the underside, between the pre- and power tubes.
    Right next to the main speaker jack, there’s an
    extension speaker output to connect an extension
    cab (8ohms), as well as the reverb Jack.
  • simonksimonk Frets: 1467
    There's a Lazy J manual...?!
    edited June 2016 tFB Trader
    edited June 2016
    Yeah .... Jesse sent me a pdf of the owners manual when I bought a J20
    I never got one. Could you send one to me or link to it etc?
    Rigsby;1101821" said:
    Yeah .... Jesse send me a pdf of the owners manual when I bought a J20
    edited June 2016
    [/quote]
    Neither did I, and I feel cheapened now. I'd appreciate a linky to it too please.
    Edit: not that I don't know how to work it...
  • WazmeisterWazmeister Frets: 9615
    The manual, I think, is the page from the website...
    Nothing mentioned about the extn cabs though. Must be another manual pdf
  • Modulus_AmpsModulus_Amps Frets: 2596
    Every amp sold in the UK should have a user manual available for safety reasons.
