All in one pedal - Verbs, Delays, Shimmer
GiacomoGiacomo Frets: 14
Can you recommend an all-in-one multi-fx pedal that can do
- Verbs
- Delays
- Shimmer
The one I have in mind is Eventide H9, don't know if there's any other out there available
With Midi possibly..
thanks!
  • TeetonetalTeetonetal Frets: 7817
    Neunaber slate with EXP (no midi) depending on what you need.
  • sgosdensgosden Frets: 1994
    line 6 m5
  • jamiexsilverjamiexsilver Frets: 404
    Line 6 M5/M9/M13
    Or zoom do a MS70CDR no midi on that though.
  • english_bobenglish_bob Frets: 5181
    Zoom MS70CDR
    Any Neunaber stereo pedal + ExP controller
    Although if you can afford one, the H9 is likely to be more flexible than either, and neither will do MIDI without some serious jiggery-pokery. (IIRC somebody here was working on a MIDI-via-USB controller for the Zoom)
    I presume you're not talking about rack stuff or full-scale multi-effects boxes that do everything since there are tons of those...
  • GiacomoGiacomo Frets: 14
    yep, no rack, prefer pedal
    But on H9 level I don't see many others..? (with MIDI)
    keep in mind that H9 is generally one effect at a time.
  • @Teetonetal Though many of the algorithms incorporate more than one effects, e.g. Modechoverb, SpaceTime, Spring reverb has a tremolo.
    I can't recommend the H9 enough, tt sounds unbelievable. If you can stretch to it cash-wise, get the Max, which means you have access to all present and future algorithms.
    I was convinced H9 can run 2 in parallel? or is this only the MAX version?
  • No, all of the algorithms are the same, whether you buy the Max or buy an algorithm for the H9 or H9 Core.
    It can't run two algorithms in parallel, but some algorithms incorporate a delay/reverb, mod/reverb/delay, etc. in one.
  • Ro_SRo_S Frets: 929
    edited June 2016
    Line 6 M5
    [edit]
     Zoom Multistomp MS-70CDR .  probably ideal if you want a compact pedal.
    maybe even the really cheap Zoom G1on
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
    Another one i remember is Damage Control Glass Nexus, but I don't know if that's any good
  • professorbenprofessorben Frets: 5105
    Are they not the first incarnation of Strymon? All ex Line6 guys.
    edited June 2016
    I think so.
  • hobbiohobbio Frets: 3440
    Another vote for the Zoom MS70CDR, I wouldn't be without mine.
    electric proddy probe machine
    My trading feedback thread
  • BeexterBeexter Frets: 617
    Yup, the Zoom multi-stomps are a bargain. the 70CDR or the MS100-bt are the ones for the sounds you've specified.
  • lasermonkeylasermonkey Frets: 1940
    Much as I love my MS70CDR, I can't help but be a bit underwhelmed by the shimmer.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
    TC G System?
  • DesVegasDesVegas Frets: 4613
    edited June 2016
    You can make your own though right by having a pitch shifter / chorus after a delay with a touch of reverb after that??
    And what about without shimmer?
    Say at least delay & verbs but with Midi?
