There are a few pedals that will sound different, mostly vintage-type fuzzes.
Ebay mark7777_1
Agree with IC, should be fine. However SLAs can put out massive current so fit an inline fuse of about 1 amp.
Dave.
That's also one of the things I don't like about these modern very-high-current (above 1A) switch-mode power supplies - they're capable of overriding the crude protection circuitry in a lot of pedals. If you reverse the polarity by accident, a supply like that won't shut down when the protection diode shorts it, it will keep on producing current until the diode burns away completely leaving the circuit unprotected, and often destroying the parts the diode was trying to save.
A 1A fuse should prevent that.
"We" used rechargeable SLAs for a time in test meters. Then a meter developed a fault and drew excess current (which an alkaline could not do) resulting in extensive burn out and swelled battery.
"More" is not always "better"!
Dave.
