*UPDATE* see several posts down for better, second demo.
OK I know, I know (!!!!) - this isn't a great recording.
I used my Zoom H2n and it was to the right of both cabs... totally off-axis!!
Also, lots of string noise and not enough cab...
However! This was just a quick recording I made when I managed to get my new Matrix NL212 cab up and running. The Matrix speakers use Neodymium magnets - the cab weighs 13kg compared to the 24kg of the Blackstar (which does include the amp section, too).
I've heard people say the Neoymium's can sound brittle etc. To be honest, unless they sounded like mud, I'd have made the compromise for sake of saving my back (the weight!).
So anyway... the soundcloud file is at the top of the page... couple things played back to back.
First time you hear the Blackstar speakers. Second time you hear the Matrix speakers.
Opinions?
Same EQ etc for both... I'm sure EQ can be dialled differently to aid either cab.
I think the Matrix speakers sound more open, or the Blackstars sound a bit more muddy. More treble in the Matrix speakers.
The true test would be a mic right in front with volume up.
1st demo:
"The matrix cab should sound good with any of the amps – some describe the neodymium drivers as being similar to a V30 but with extra clarity in the low end. The victory cabs come loaded with either V30 speakers or creambacks, which are a little mellower sounding with less high cut, making them well suited to cleaner tones. "
I can't decide, listening back, if the Matrix cab sounds more nasally, or if the Blackstar sounds more muddy. I'm guessing the Matrix would cut through more in a band situation.. I think I prefer the Neo speakers - they sound more natural to me. Though I may be talking bollocks - will be good to hear what you think.
My YouTube Channel
My YouTube Channel
However...string noise, dude
It's interesting that the Matrix sounds good with the Blackstar ID, though, because they're notorious for not sounding great with anything other than the stock speakers.
Try playing louder, perhaps do a quick 2 minute comparison at volume at rehearsal.
However, I must admit, the tone from that Blackstar really is impressive for a cheap-ish modelling amp. I really think they hit the nail on the head with that one. I tried the 2x12 combo and the stereo effects coupled with a very, very well voiced set of models made it really easy to get excellent tones.
I vaguely remember the smaller ones missing a presence control or something, so they may not be so easy.
The ID series sounds pretty good through Mesa V30s, having tried it through Rectifier and Stiletto 2x12s. It sounded pretty decent through the Recto cab actually.
I quite like the perceived size and punch of the Matrix cab but it is hard to tell given the volume and proximity of the actual strings of the guitar.
My YouTube Channel
My YouTube Channel
I'm pasting this in the OP as well.
My YouTube Channel
In fact, if I go to edit a post with a soundlcoud link, the link disappears.
Anyway! Let me know what you think of the speakers based on this second demo.... ignore the shoddy playing - it was just a quick demo!
My YouTube Channel
BUT that could all change in the context of a mix and I know I've set up tones that sound good at home and get lost with a band many times.
Those recordings must be very quiet if I can hear the string noise direct from the guitar so it will all change again when it's at proper volume.
I'd try both cabs with a band and see which you prefer then.
In fact it's good you didn't know which was which - the blind test has worked!
The amp wasn't booming loud - my Zoom H2n just seems to be super-sensitive.
Definitely be good to try the new speaker "in the mix" / band setting.
My YouTube Channel
In case anyone is wondering why "I" have not chipped in? It is because I do not have the first idea what a Blackbird actually is! I would not be able to hear very much difference anyway.
Just a point tho', if you want to compare speakers the best test source is pink noise (Audacity) use an SDC mic and stuff the results into Rightmark Anny-lizer.
Dave.
My YouTube Channel
Yes but when you use musical signals you are hitting it with DISCRETE frequencies, even heavy distortion is just a series of discrete "spikes" . Noise gives you the complete spectrum of the speaker, akin to playing every tune in every key. RMA can give you a printout of the spectrum (invert the colour!) and thus you might be able to see WHY the speakers sound differently.
If you insist on a guitar input at least use a constant one, a re-amped loop!
Dave.
