DV Mark Mutliamp (stereo) for sale !!SOLD !!
Selling my Multiamp due to a recent purchase, love this unit but it's way too much that I'll ever use.
Been gigged three times but mainly home use, realised I only ever used two or three sounds
![](/plugins/EmojiExtender/emoji/fb/2.gif)
Basically it's a three channel pre amp with about 6-8 amp in each channel, Fender, Vox, Boogie, Marshall, Bogner etc plus pre and post effects, cab sims, different mics etc.
Great tone and feel and sounds great cranked.
£800 with rack case ....no trades ... will accept PayPal if you add 3%
As seen in photo ...
Input: 1 jack mono
Outputs: 2 jack mono (left/mono,right) / 2 XLR male (left/mono,right)
Channels: three (clean, crunch, lead)
Controls: gain - presence - level - master
EQ Controls: bass - mid - high
Power Amp (solid state): 150+150W@8ohm / 250W+250W@4ohm / 500W@8ohm (in bridge mode)
MIDI connections: in - through
Other features:
virtual amps
speaker cabs and microphones
effects
external memory (SD card*)
* SD Card FAT 32 format, max 8Gb
Dimensions: 2U standard rack - depth 12.76”/324 mm
Weight: 9.48 lbs / 4.3 kg
#thebatesmotelband
