DV Mark Mutliamp (stereo) for sale !!SOLD !!
  • BGGBGG Frets: 689
    It's easier than an Axe FX etc etc.
    The built in presets are a canny starting point but basically to set a patch up you have a choice of three channels, clean amps, crunch amps, and higher gain amps. There's not hundreds but maybe 6-8 in each channel. Tweak to taste then add effects if needed pre or post amp. Then there's cab sims if needed for recording/direct out but again not loads and loads.
    #thebatesmotelband
  • SpikeedogSpikeedog Frets: 43
    Once you've got them though how quickly can you bring up a specific patch... Does it involve scrolling through them?
  • BGGBGG Frets: 689
    Yes if you don't use a midi controller. But you could save them all in a user bank and scroll through them as needed.
    But with a midi board it's instant access to the patches.
    Have a look at this link ...
    #thebatesmotelband
    Very interesting......very complicated but I guess once you've programmed it, should be easy to recall presets and control effects. Thanks.
  • BGGBGG Frets: 689
    Honestly, easier than most, set your fave patches then just tell the foot controller where you want them ;)
    #thebatesmotelband
  • stanstan Frets: 190
    Hi, how old is your multiamp and does it have any updates installed ?  thanks,  Stan.
  • BGGBGG Frets: 689
    Sorry Stan it's sold.
    #thebatesmotelband
    Pity ...thanks for the heads up.
