The A15 being cathode biased does not chuck out more than about 20W at fill chat and top mains in.
This means a power soak can be of quite simple design and need be rated at no more than 50wattts. I know the company does not really approve of soaks but when the devil drives???
Maybe some enterprising bod here could knock you one up?
Dave.
My YouTube Channel
I can gig with my laney cup 12 on it's <1W mode. It's very loud, sounds awesome cranked.
You are thinking about this all wrong.
Low watt does not mean it sounds any good quiet. It means it's easier to crank the thing and have THAT valve sound at a lower volume.
@ICBM has often said it's better to have a big amp turned down, for low volume playing as the amp itself imparts bigger body to the sound, plus you can use pedals etc for gain.. I many ways I have to agree. However, for people like me , who live in a very small flat, have a baby etc, almost any valve amp is too loud. modelling is a much better option, as are VSTs etc.
After that factor in speaker sensitivity, quality of master volume implementation etc, etc
I'm hoping the power scaling on my new amp does wonders for bedroom levels. But yeah, modelling is perfect for the bedroom!
My YouTube Channel
Actual bedroom volume is more like 1 to 10 *milliwatts*, into a decent-sensitivity speaker.
1W into a typical 12" guitar speaker will produce around 100dB one metre from the cab. 10mW will still give 80dB. .1mW would give 60dB, which is 'conversation volume' - assuming the speaker is linear that close to the bottom end of its travel.
So forget cranking any valve amp, without some sort of power reduction or attenuation. Even my ZVex Nano - about 0.1W clean, 0.5W flat-out - was *way* too loud for playing in the evening without an attenuator.
http://www.gcaudio.com/resources/howtos/loudness.html
My YouTube Channel
If you have master volume even better...you can dial low volume/high master of high volume/low master to get different clean/dirty tones at low volumes. Alternatively...change wife. haha
Wow, do you still have the Major ? Weren't they supposed to very unreliable ?? Don't see many around. Thks to them in the 70's my hearing is not what it was LOL
You probably couldn't hear them screaming at you to stop playing.
Not really, although probably a bit more so than a standard 100W Marshall.
I played it very quietly. I had an outboard valve preamp that I made with a 2203 preamp circuit in it, then through delay etc, then into the Major with the volume at about .001
The only time I ever got a complaint was from playing my 5W Marshall Mercury.
Like I said, it's easier to get a great sound at really low volume from a big amp than a small one.
