I have the Jettenuator for recording/home use and its been great.
Not used it with the band yet so cannot comment on that.
Its built very well if that helps.
Cheers
Mark
APOLOGIES if I have hijacked a thread here, and if you don't like it I'll remove and start a new thread!
Mind you, I use a smaller amp now so the J'tor has been popped away in it's box ever since!
Trading feedback here
Flat out does not sound good to me.
I also use it with a Blackheart BH15 and again, flat out is not the sweet spot.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
(formerly miserneil)
My music:- https://soundcloud.com/hubobulous
Rift Amplification
www.riftamps.co.uk
I've just built a 5E5-A Pro that measures 30w RMS clean, 62w peak power (1kHz 150mW sine wave into 8ohms) so this attenuator could easily be modded up to 100w working power for his amp.
Rift Amplification
www.riftamps.co.uk
Bearing in mind that if you do burn it out you're very likely to seriously damage the amp as well… it doesn't pay to be optimistic with attenuators
Rift Amplification
www.riftamps.co.uk
