Has anyone seen these? This is a picture of the 4 loop, but they also do a 3 and a 2.
http://www.woundedpaw.com/fx/It may be of more use to bassists, but it seems pretty cool. The EQ is on loop A, which if nothing is plugged into it is just your dry signal. In theory quite useful for bass guitar, as you could reduce the treble of your dry signal but keep some clean bass to blend with drive pedals. The V4 version can also run C into D, D into C, or have them parallel, allowing for some extra stacking as necessary.
On a secondary note does anyone know about other blenders that have tone controls that can affect just one loop?
I'm not interested in EQs that affect the whole signal. Ideally I'd want a lowpass on the clean signal and a highpass for the loop (to keep the lows for the clean signal and the highs for the distortion).
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
but you could just add an EQ pedal or a Timmy or something in that one loop.
