Blackstar pedals?
baddog01baddog01 Frets: 8
have any of you tried any of these pedals? What are your thoughts?
  • mike_lmike_l Frets: 5700
    I have a LT Dist. It's a fantastic unit, has enough gain for Van Halen/Iron Maiden style. But is way more flexible than that, it'll do a nice lightish crunch, right up.
    Well worth the £not much that they cost.
  • They're really nice sounding pedals. I've had the Lt boost which is genuinely fantastic (sold when I got a juansolo boost) and I've tried the Lt overdrive.
    Underrated.
  • I see there is a LT Metal for sale locally but I don't know if I liked it in the demo. I thought the other ones sounded good. Hmm
  • I have a Marshall Guv'nor clone and an OCD knockoff. Do you think either of these would be comparable the the LT distortion? I hate it wen I buy an pedal and it sounds like a pedal I already own. :)
    The Guvnor does a great Marshall JVM cranked sound, the LTD would be put in this category, but when I put the Mk1 (or Mk2)  guvnor in comparison the the LTDthey sound quite different.
    I'm not familiar with the OCD so can't comment on that.
  •    I can get the OCD and Guv'nor to sound really close to each other but the Guv'nor is more flexible. I can get a wider array of tones out of the guvnor  with its full eq.  The OCD does a good clean boost as well as distortion.
  • If you already have two OD pedals, you are best trying others first before buying as, like you say, a lot of them can sound the-same-but-different.
  • hugbothugbot Frets: 1528
    They're alright, they sound very amp like, albeit a blackstar amp.
    its funny, I don't like the sound of blackstar amps much at all, but when the exact same sound comes out of a pedal, I'm super impressed by how amp like it sounds.
  • GassageGassage Frets: 31016
    I recall being mildly impressed by the multi mod pedal for this price.
    You can get them pretty cheap on Amazon, sometimes they will reduce the price of them quite a bit.
  • The wife and I have Amazon Prime. Might have to see what they have for pedals....
  • cbilly22cbilly22 Frets: 360
    Underrated.
    Agreed, I'm on my 3rd LT Boost and hopefully won't be stupid enough to sell this one.
        Good point. I have a couple OD pedals on the board already. Marshal Guv'nor Clone, Klon Clone, Modded TS808 and a Joyo Ultimate Drive( OCD copy).  By mixing pedals I should be able to get a good variety of tones. It's odd, I think I have a small pedal addiction problem brewing:)
  • Don't forget about amp OD too. If you are a bedroom-player, you won't need as much drive once you start playing out because of volume/loudness
    4OD's is an amateur attempt at a pedal addiction problem...........
  •   What if I said  I had 6 OD's....:)
    I'd say buy more.
  • I'm trying but the wife keeps track:)
    I'd say, its a start, but you have a long long way to go........
  • MossMoss Frets: 2409
    I'd say get off the drugs ASAP
    Stop crying, start buying
