http://m.ebay.co.uk/itm/Carvin-Vintage-Tube-Nomad-50-valve-head-/361679154321?hash=item5435c1ec91:g:mhEAAOSwvg9XVCpZ&_trkparms=pageci%3A591ccc05-61f5-11e6-b121-005056b041ad%7Cparentrq%3A88122a701560a2af6f3af422fff34a34%7Ciid%3A1
So imagine my surprise to be massively impressed with the THR100 head...
It was going through a Marshall 4x12" though, so it may be the speakers that make the little one sound bad.
Or the Youtube players
The cleans on both sounded middly - there was no real sparkle or 'air' to them - no better that most cheaper solid state practice amps I've heard.
The drives really lacked any kind of usable touch-sensitivity - not valve-like at all.
Given their price, I was massively underwhelmed.
What about a hybrid amp @hootsmon ? I had one of the first Vox Valvetronix amps and it sounded good and had a control on the back that you could turn down the wattage.
My YouTube Channel
Apparently some manufacturers make inefficient speakers on purpose for home us!
My YouTube Channel
Eminence make a speaker which actually has a sensitivity control on it - a big dial on the back of the magnet - but even that starts to sound progressively less good as you reduce the sensitivity, and I don't think achieves more than about 10dB reduction at best.
(except for Offset owners to argue about bridge choice)
My YouTube Channel
[/stuck record]
The single tone control is more limited than a 3-band EQ, but the overall tone is well mannered - not harsh, not dull, and the tonal range is pretty good. The stock HH branded speaker is okay but nothing special (reputed to be much better than the Celestion Tube 10 that they were originally fitted with).
It goes pretty loud when cranked, but can start to sound a bit boxy. Clean notes can sound a bit harsh at times when it's up loud, but I'm not sure if that's how my ears are responding or maybe the speaker. Plugged into a Harley Benton 1x12 V30 cab, it sounds bigger and tthere's a bit less top end. Loud with this amp is a weekend afternoon thing - if it was a TV, it would be considered blaring and way too loud. At sensible home volumes, it's fine - good bottom end and generally more balanced sounding. For clean playing, I'd say the tonal character leans towards sweet sounding (or slightly dark, depending on your perspective), especially for single note melodies and broken chords. That sweetness carries over into the edge-of-breakup clean sound, and the transition between clean and breaking up is easy to control with pick attack.
The amount of drive with the gain at max is in hard rock territory when playing chords/riffs with PAF-style humbuckers - about AC/DC crunch levels with the master well down (so no power amp distortion). Not enough gain for me when playing lead, but it can be pushed into high gain sounds with a clean boost or overdrive. With amp crunch, it cleans up nicely with the guitar volume control, whether used with pre-amp gain or the power amp overdriven. Again, it can sound a bit boxy when cranked up, and this improves through the V30 cab. The drive channel is a bit milder with the single coils on the Red Special, and I'd want to use a pedal with that to get a bit more crunch.
For home use at TV volumes, with a variety of sounds, especially if reverbs and the like are included, it's better used clean with pedals in front - it does take pedals well, and the tone can be further tweaked with an EQ pedal. The boxiness isn't really evident at sensible volumes when jamming along with TV or stereo.
I originally bought mine to use with harmonica (and it was too loud), which led to me rebooting my guitar playing (which had stalled for a few years). If I was looking for such an amp now, I'd probably want to try the Cub 12R as well. It costs £90-100 more, but it could be argued that the 12" speaker, 3-band EQ (plus the 'tone' found in the Cub 10), effects loop and low power mode are a lot of extra features that might be worth the increased spend.
Overall, I'd say the Cub 10 is more versatile than the limited feature set suggests, although some of the sounds require it to be cranked up. It's really a bit too loud for power amp crunch at home unless you have co-habitants and neighbours that are either tolerant or prone to going out for a couple of hours, leaving you to rock out. I'd consider a speaker upgrade if it was to be my permanent home amp, although it's notable that most people that post reviews decide that the speaker is sufficiently okay to not bother upgrading. I didn't either, but I got a Blues Deluxe instead and that's been my home amp ever since (I plugged into the Cub 10 today for the first time in months).
Would I buy a new Cub 10 today? Probably not. I'd definitely shop around - I'd at least try the Cub 12R and if I liked it, maybe seek one out second hand for similar money to a new Cub 10. By the same token, a new Cub 12R is getting close to used prices for amps that are better again. On the other hand, a used Cub 10 could work out pretty cheap (and cheerful) and probably sell on for the same price.
Nomad
Also yep.
For me,...end of errand.
