All 1922s apart from the very earliest ones are MDF. 1936s were ply, then MDF for a long time, but have now gone back to being ply.
To me, the 1936 sounds worse - boomier and less focused, and doesn't project all that well - than the 1922 if both are MDF, but a better if both are ply. I'd take an MDF 1922 over an MDF 1936 probably, but a ply 1936 over either… if that makes sense.
But unless it's for a Marshall head I probably wouldn't buy a Marshall cab anyway - they're both massively overpriced compared to what you can get if you're not bothered about brands, especially the Harley Benton G212V which is a proper ply cab with V30s for barely more than the cost of the speakers.
I guess the morale of the story is, the 1936 is nothing special.
http://thefretboard.co.uk/discussion/82310/
All-ply, sounds great and looks fantastic. Not as big as it looks either, and easy to carry.
The only slight problem is that the speakers are mounted diagonally, and for some reason soundmen always seemed to mic up the wrong corner, thinking it was a 4x10". Although not really a problem since they would then say they weren't getting much level from the guitar and ask him to turn up
I am not affiliated to Brize
I quite like the 1980s Marshall 1966 2x12s (as well as the matching 1965 4x10s), but they’re even narrower than the 2061CX at roughly 24" wide.
What have I done... maybe I should have started a FS thread :P
its closer to the 1922 in dimensions than the 1936 I used to have, tbh I found the 1936 a pain in the arse of you are going to take up that much room onstage, might as well get a 4x12.
The 1922 is a lot tighter and more focussed.
These days I run into a pair of Orange PPC 1x12s which sounds great. The 2x12 sounds even better but Christ its Huuuge and very heavy.
Other good 2x12s are the 65 amps one but again it weighs a ton. The Buddah one is very nice but very deep doesn't suit all stages.
