Three and a half thousand quid… hmmmm...
That one just needs a bit of TLC. It's a shame about the big logo, if the box has been drilled for it - everything else can be put right easily. If it's just been stuck on it should be fixable. The best thing is that the front plexi panel is in *very* good condition.
I can get you another one if you want . It's got a stripped cabinet but the chassis in slightly better condition than this one I think.
What was it sold for on Ebay - around £2k?
The early SS-rectifier JMPs continued using the same PT for a while, so there is an unused valve rectifier winding, and the voltage is over the rating for the first filter cap - although it doesn't seem to blow them.
I'm sure you'll be able to sort the rest of it out though!
