Just hit the button on one of these,
Great service from guitar guitar again. I am hoping this one is going to replace thee JJ and the Butterslax.
Anybody used the cab clone to record on this amp?
My YouTube Channel
I have to say that's good going - deliberate for months on whether to get a valve amp or not, then buy three of them!
My YouTube Channel
In the speaker-off mode, you get silent recording but the cab clone provides a non-reactive load and doesn't behave like a typical speaker.
The cab clone out also provides a speaker/cab simulation - it cannot be disabled in the DI-out. But as an alternative the slave out can be used to capture the sound after the power amp stage. To be honest, I find the cab simulation to be rather poor!
For recording, I have had far, far better results using a Torpedo Reload and a set of impulse responses.
If I didn't have a reactive load, I would use the cab clone to load down the power stage, but record the slave out rather than use the DI. Applying an IR to that signal is going to sound infinitely better than using the inbuilt cab clone simulation.
