If you do use pliers use a wider one and put a @mike_l between the jaws to protect the metal.
You might be able to reuse the existing fine tuners.
I use a high grade abrasive paper to remove the rust and then some Liberon lubricating wax to protect the areas.
Once you get them free or if you have to get new ones, put a tiny amount of copper grease in the threads, that will hopefully stop them seizing up again.
Do I have to think of everything.
Might be worth covering the bridge posts with masking tape while the bridge is off to stop them being accidentally turned.
EDIT: just realised it's a fixed bridge, ignore what I'm saying completely!
