The germania's very good at pushing your amp into singing sustain if that's your thing. The silicon TB has got a lot of range from thin to rich and bassy.
Don't bother using with a solid state amp. They'll sound horrible.
Where did you get the TB from, cant seem to find any info on it?
@dodge makes a good suggestion- Rangemasters are very simple circuits so building one yourself is not a huge task, even for a beginner at DIY electronics.
The hard part would be finding a suitable germanium transistor since they're obsolete and notoriously inconsistent, but buying a kit should mean that the hard work would be done for you in that respect.
It's one of these. I don't think they're still being made. Got mine secondhand quite a long time ago.
It's got loads of dip switches inside for varying amounts of bass.
It's a very simple build, should you be into DIY.
I said maybe.....
https://www.dropbox.com/s/n37z9r1rl5s6zye/IMG_3975.jpg?raw=1
Apparently Dave Main biases them at 6.66v, but then he would!
I said maybe.....
