"I like the variable option to tweak high end focus."
I assume you amp has a tone control of some sort?
As Thorpy says, buy a tuner (other buffered pedals are available) and don't get suckered in by everything you read, until a few years ago no-one even knew they 'needed' a buffer
Have a Polytune as first pedal, and my LJ20 has one tone control, probably sorted then!! Saved me some cash today...ta
If you want a separate buffer the Fredric Effects one is tiny, £40, based on the Klon one and seen on a few boards on here.
Yes - no buffer in a polytune
out of what i've tried, i like the one in the EHX soul food (which i'm guessing is the klon buffer).
