A couple of days back, I was mowing the grass and I happened to check the grass collector, to my surprise I found a £10 note in there! (It was quite long grass....so didn't spot it before, just ploughed through it. It was an area of rough ground behind my home where I have a rear gate to access a track, which is unadopted). However, its not complete, its about 3/4 of the total length it should be. Luckily, the bit with the serial number was retained, the other bit chopped off.
Is it still legal tender? Can I use it in a shop (I imagine the shopkeeper would be a bit miffed!) If not, can I swap it in a bank? My bank or any bank? My bank doesn't have branches, it uses the Post Office as an agency service for paying in cheques/cash etc. Can I go to a Post Office to swap it or must it be a bank?
take it to your bank. they will have a list of requirements that it must meet. I cant quite remember them all now but from the top of my head it must be more than half the note. must contain both serial numbers. I think theres some requirement for the phrase "i promise to pay the bearer.." but Im not certain.
If youre doesnt meet the "standards" they will supply you with a form to send it off as a mutilated bank note. it gets sent to whereever and they pay you out! This sometimes takes a little longer but you will get the cash!
http://www.bankofengland.co.uk/banknotes/Pages/damaged_banknotes.aspx
ah thats the form I was on about. Didnt know you could get it online. If I was you I'd send it on to that and save yourself a trip to the bank coupled with some poor customer service ;-)
soundcloud.com/thecolourbox-1
