  • Damn only one available, needed 2 :(
  • Maybe it's worth it if you have a '54 tele missing it's bridge pickup?
    It's not like you can buy one at Strings Direct?!
  • cheers for the link, I'm looking for one that reads a mild 6.54k rather than a strong 7.10k
  • randellarandella Frets: 4220
    edited September 2016
    On the one hand, yeah.  It's a joke. For someone to whom (like me) the whole vintage thing is anathema, spending an amount of money like that on a pickup seems very silly when the same amount would probably get you in to the low end of the Custom Shop for a whole guitar.
    Then again, what would a playable '54 Esquire cost? Guesswork - £20, £30k?  If you had one without a bridge pickup, probably a lot less. If you've got that sort of wedge to drop on the guitar, £2.1k for the pickup starts to make more sense.
    I doubt it it would do much for a Mexi Standard though :)
    Edit - beaten to it
    Edit - beaten to it
    You said it better though ;)
    Edit - beaten to it
    Very kind of you! It doesn't happen often :)
  • EvilmagsEvilmags Frets: 5158
    Stick that pickup in ten teles, and you´ll have ten slightly different sounds. Stick a load of bare knuckles, oil city masterwounds, lollars, fralins, bulldogs ect in the same guitar and nobody would be able to spot the original.
  • bbill335bbill335 Frets: 1385
    I've been looking through their store. I'm a fan of this body, which is both sonic blue and seafoam green, and yet it is neither.
    At least he had the decency to put this once-special guitar back together with buLLSHIIIIT REPRO PARTS
