Trading feedback | FS: Nothing just now
JM build | Pedalboard plans
Loads of different sizes on ebay.
@Sassafras cheers - Neoprene sounds like what I need.
Just did a quick google and found people saying they had measured surface temperatures above 200C on EL84s. Obviously this will be vary depending on the type of amp and tube in question, but it suggests I need tolerances quite a bit higher than those in the links above.
I've not used it but I read that neoprene rubber, the dense stuff, will stand up to high temps up to 260C but I don't know if it's a special type.
I remember I had a Peavey amp that used what looked and smelled exactly like neoprene to cushion the valves (EL84s).
