WTB: Analog Delay with Tap Tempo
  • TimmyTimmy Frets: 23
    Have you tried an el cap? With the tone and eq controls you can make it sound quite analogy, got it to sound verry close to my memory man. The hold feature is very good and musical, diffrent chords blend well and you never get any funny harmonic clashes when playing on top of it(hope that makes sense) you can set it to go crazzy as well but if you want to play notes over the wash or change chords whilst holding the self osolation this might be the one for you. Having the option to put reverb just on the repeats is also verry useful as a big box memory man sounds like it has reverb. Deffinetly worth Trying. You can really tweak it to how you want and I have found it to be the most versitile "small delay" I have used
  • I haven't tried one, no. They're obviously quite expensive so it's quite the endeavour to drop £180-£200 I don't have on something I might not want. Having said that, its not like i couldn't get shot of it. There's one in Dawsons locally i think, maybe I should pop in and annoy them :D
  • Hold to oscillate pretty much a requirement; chase mode is a bonus.
    That's a supa puss isn't it?
  • @meltedbuzzbox No hold to Oscillate on the Supa-Puss unfortunately; which is a real shame. You can't get it to oscillate with an expressive pedal either.
    The only pedal that has both features (sort of) is the Deluxe Memory Man TT; although it only goes through the different subdivisions in sequence whereas the Supa Puss has 5 different patterns it runs through
  • bump
  • Got an re20 if that floats your boat
  • colourofsoundcolourofsound Frets: 403
    edited September 2016
    @wayneirie cheers bud but really after analog bbd chips. Heart set on it.
  • Bermp
  • bump...?
  • No DMM TTs about then?
  • Could you get an external tap tempo switch that works with an analogue delay?
    @BintyTwanger77 It's actually the hold to oscillate function i'm really jonesing for. Generally pedals that have that function access it by holding down the TT footswitch.
  • BintyTwanger77BintyTwanger77 Frets: 2274
    You could attach an expression pedal to something like a Minifooger delay. I think the exp controls the oscillation.
  • How you getting on with this Colour? The EQD Avalanche Run looks the shizzle to me..... I am saving for one!
    @Placidcasual79 Having difficulties finding anything used. Considering a new DMM TT 500ms. I think i'm going to wait for the Stone Deaf Syncopy to come out though; Chris at Custom Pedal Boards will stock them so i'm going to demo one with him. It's got presets!
    Avalanche Run does look ace but still sounds distinctly digital to me!
  • Still want one!
  • sweepysweepy Frets: 4213
    My Way Huge Supa Puss would fit the bill, mint in box etc etc ;)
  • @sweepy That has been on my list. I am very tempted. It doesn't do hold to oscillate though...how much?
    £160 inc p&p for the Aqua Puss, but always open to offers
  • andyozandyoz Frets: 718
    Supa Puss is class.  The gain adjustment to repeats really give it a nice rock tone but it never seems to get harsh (even using R9 with a pretty hot bridge pickup)
