So - I have encountered a huge issue with everything today.
My house appears to have an earthing issue.
I am getting the most hideous amp distortion (like an amp tranny dying). It sounds like bacon and eggs frying through the speakers.
Firstly, it happened when I was playing the Deluxe. I thought it was something wrong with the amp. So I switched to the Hiwatt- the same- the L40- the same.
Horrendous noise everywhere.
So I changed all the amp power sockets and plugged in elsewhere. Still the same.
So I then thought it might be the rack- went directly into the amps, still the same.
Shit, I think- so I take the Deluxe into the lounge- STILL THE SAME. Take J40 into lounge- arrrggghhh...you got it, still the same
It is raining hard today- could this be it?
I have no clue what's causing this other than the earthing.
So so so annoying,
Any ideas?
Is there something else running in the house today that is an occasional thing (heater? Fridge? new lamp?) It might pay to go round the house isolating things one room at a time (pull the plugs) and see if the noise suddenly stops. You willl have found your culprit. If you are in a building shared with others then it may be outside your sphere of influence. It could be the bloke next door welding up his Harley frame with a stick welder. Dirty power will tend to sit in a very local area, there are ways to get 'clean' or even balanced power into your gaff for silent running of audio eguipment, most serious studios have such a feature but the cost is not negligable. Cheap surge protectors like those 4 bar trailing socket jobbies are - just big brown jobbies for serious use. You can try something like a UPS power conditioner to see it the situation improves, make sure the electrical consumption in watts from the amplifier or rack is exceeded by the UPS device by a reasonable margin, whilst your amp will draw much less than maximum power at home volumes, the start up current can be hefty.
Or get a furman (other types are available) power cleaner for the rack. They even do balanced power packs for those with credit cards bursting....
(see what I did there?)
All this swapping of amps, was it with just the one guitar and cable?
Does you TV picture and sound system exhibit any 'noise'?
When a combo is just sitting with nothing plugged into it but the controls operated, does it still fizz?
Does you Furman have a voltage display? Back in the day it was a technique used to reduce the mains voltage with a variac and starve a valve amp so that it distorted at a lower volume, if your incoming mains is low it could just be that making for power distortion, that is not likely to cause fizz and pops type noise though.
http://www.russandrews.com/mains-power-russ-andrews-mains-cables-superkord-range-superkord500/
(Not really)
Just doing a sound clip!
https://www.facebook.com/james.while.10/videos/vb.669737065/10153930854177066/?type=2&theater¬if_t=video_processed¬if_id=1474906406075753
Drives me bonkers. But at least I can fix it - it could be something a neighbour has plugged in.
https://www.facebook.com/james.while.10/videos/vb.669737065/10153930880437066/?type=2&theater¬if_t=video_processed¬if_id=1474907107281836
