AvalonAndyAvalonAndy Frets: 326
edited January 2019 in FX
  • MattFGBIMattFGBI Frets: 1602
    Does it happen on both channels? Have you tried swapping any valves?
    This is not an official response.
    contactemea@fender.com
  • fretfinderfretfinder Frets: 5100
    The two times this has happened to me over the years was once a valve dying and the other time a transformer on the way out.
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
  • ICBMICBM Frets: 72945
    First try removing all true bypass pedals, especially the EH.
  • AvalonAndyAvalonAndy Frets: 326
    edited January 2019
    edited January 2019
    edited January 2019
  • If in doubt, rip them out :-P
    Try replacing them with Planet Waves/Daddario cables (the ones I have - good quality and value) or Fender custom shop cables that most big guitar shops have for £5 a pop.
    Then when all the Planet Waves and Fender Custom Shop cables have failed, replace them with something good... it shouldn't take long.
    Those two brands are the most unreliable cables I've ever come across, worse than the cheapest cheap crap.
  • SassafrasSassafras Frets: 30320
    Plugs on Fender cables are rubbish as ICBM says.
    I've seen more broken Fender cables than any other bit of sound equipment.
  • hywelghywelg Frets: 4316
    Op says all leads are KABL. Try swapping your patch leads for KABL as well.
  • bbill335bbill335 Frets: 1391
    Hosa are great.
    edited January 2019
    If you've got a soldering iron you could always knock up your own patch leads.
    Sommer, Klotz or Van Damme cable and decent pancake jacks. That way you get exactly the size leads you need.
  • SporkySporky Frets: 29046
    Thanks for the replies gents.  I like my kabl cables, but I find it hard to justify £43 for 5x10cm cables.
    In a decent cable it's the plugs and assembly that make up most of the price - the cable itself is pretty cheap.
