tele 52 RI bridge grub screws
HootsmonHootsmon Frets: 15999
is there a drop in shorter replacement of the same size available in the UK?
a couple sit too proud on my tele and I can't be arsed sawin' shit
tae be or not tae be
  • RandallFlaggRandallFlagg Frets: 13964
    edited November 2016
    I have a 2015 AV52 as well.
    Man up and grind that palm muting out until you bleed, heal and get a hand as rough as a breeze block.
    The tone is completely lost if you use fractionally shorter screws
  • richardhomerrichardhomer Frets: 24851
    Lacerations are all part of the 'vintage' experience.
    Personally I'd get my hacksaw and a file out. It not a 'massive' job.
    The other option is increasing the neck angle by shimming it - so with the saddles set at the right height - they are higher up the screws.
    I'm not a fan of this option - as I don't like the idea of a shim - but it's probably the quickest/cheapest fix.
  • gavin_axecastergavin_axecaster Frets: 527
    I carry 8mm long slot head 6-32 grub screws for this very purpose.
    http://www.axecaster.co.uk/index.php?main_page=product_info&cPath=9_26&products_id=243
  • Jimbro66Jimbro66 Frets: 2431
    That's useful. I'll bookmark those :)
  • HootsmonHootsmon Frets: 15999
    Flaggy
    how's the neck on that 2015?
    mine is a slim(ish) 2007
  • Philly_QPhilly_Q Frets: 23203
    Yes, it's not difficult to get hold of #6-32 grub screws (or #4-40 ones for Strats, I think that's the right size).  Quite easy to find on eBay.
  • hootsmon said:
    Flaggy
    A nice chunky handful, but I love a fat neck. Not as fat as my R8 Les Paul though
  • ICBMICBM Frets: 72709
    I actually prefer it - I find it makes the guitar sound better as well as curing the saddle screw problem. I don't know whether it's the shim, the extra pressure on the saddles, the increased break angle or a combination of all those.
    On a vintage-style bridge it also helps lift the strings clear of the sides of the bridge tray, which makes palm muting easier - and means you have the pickup slightly higher too so the screws are tighter against the springs and the pickup has less tendency to rattle.
    Just better in every way, and you don't even need a very thick shim usually.
    the strat grubbers a different size then?
    Yes, they're a narrower width (and shorter length).  I checked the size, #4-40 was right.
