This is the 21st SOLO of the Month (SotM) Challenge, being run by @Antique_Guitars and @TTony.
We give you a new backing track to solo over every month. The backing track will be a maximum of 1.5mins long.
You download the track from our soundcloud page, record your solo over the top of it and then submit it to us.
Challenge #21 is now open, and remains open for submissions until 24th November.
Voting opens on the 25th of the month, and closes on the last day of the month, when the winner will be announced.
Here is this months backing track (you can download it from soundcloud)
Send your tracks to solos@theFB.co.uk
The tracks will be uploaded to our SoundCloud account and saved in a playlist that will be linked below
https://soundcloud.com/thefretboard/sets/sotm-21-2016-11
Old Is Gold
Thanks again @stratman3142
It's usually under the ---More button.
<edit>Actually, wis'd what @stratman3142 said, that's a good idea!
anyhow.. been neglecting this for a while, so thought I'd stump up an entry. already sent in fancied a jam!
I spent a fair bit of time constructing something for this months solo; played in pieces until it was right in time and in tune. Then lost the lot when the DAW crashed!
In my frustration decided to just blag something. I knew i wanted to start of with the Fuzz and then come in with the Vibe so I did that in two separate takes (my Zoom G3 isn't on the floor for me to use the footswitch).
It's a bit noodley but i think it's alright.
Good Luck all. Look forward to hearing your take on it.
Entry on way...
As long as you lot don't discover my creation, the "Note Shift" Technology I use. It puts all the wrong notes in the right order to create the right notes in the right order.......oh damn, rumbled now
When I first listened to the backing, i thought the same as Paul. It doesn't really change until the end and then it cuts off, but once I listened to it a few times i started hearing a simple theme and worked around that.
