Beginner Cyclist needs help!
  • holnrewholnrew Frets: 8207
    If you're a beginner you might need stabilisers.
    My V key is broken
  • sev112sev112 Frets: 2817
    If your bike isn't worth much then seriously decide whether you want to spend loads of money on an EXTREMELY HEAVY D. Lock.  They weigh a ton.  For low value and low risk storage just get a light combination or key lock.
    then spend that money on GOOD REAR lights and probably 2 at the same time
    shy away from really bright front ones unless you are on dark unlit roads / canal paths, and if you do get them, take special car to make sure they do not shine at oncoming drivers.  If you blind them then don't be surprised of they then crash into you.
    i reiterate, one small flashing red light is not visible on dark wet nights.  That IMHO is the best investment
    helmet needs to fit too.  Not just be adjustable, it needs to fit your head shape so try a few on
    decathlon have loads of good value choices
    enjoy :)
