Using Fuzz with a switcher (Boss es5)
TeetonetalTeetonetal Frets: 7815
Given that lots of Fuzz hates buffers etc - is it even possible to use something like the analog man BC108 with a Boss ES 5/8
Is only solution to have the fuzz upfront before the switcher?
  • GassageGassage Frets: 30947
    No. Get a fuzz or muff that isn't buffer sensitive. The Fallout is fine.As is a RAT.
  • True - just it's not always easy to know what reacts and what doesn't
  • @Magnetic_Effects any issue with your fuzzes?
  • I have a diy build article from Guitar & Bass for a transformer based 'pickup simulator' box that supposedly overcomes this issue (basically, it has a high-impedence output - like a guitar pickup - and some basic gubbins to 'tune' the sound slightly).
    I have no idea how accurately it replicates direct-to-guitar but it's a pretty simple circuit that fits in a small enclosure. I can send you a scan if you're interested although I'm sure something similar must be online somewhere.
  • Thanks @steamabacus ideally I'd like to avoid having an extra box on the board - would rather just by a Fuzz that works :)
  • Magnetic_EffectsMagnetic_Effects Frets: 135
    edited November 2016 tFB Trader
    @Teetonetal All my fuzzes work totally fine with buffers. I designed them to be buffer friendly.
  • vasselmeyervasselmeyer Frets: 3674
    I have a @Magnetic_Effects White Atom with my ES-8. Works perfectly.
