LP Kit Build
DannyPDannyP Frets: 1682
edited November 2016 in Making & Modding
My Uncle bought me one of these for my birthday:
«134
  • DannyPDannyP Frets: 1682
    I fancied an open book headstock, not because I want to pass it off as a Gibson - but just because it looks "right" to me
  • DiscoStuDiscoStu Frets: 5556
    Which company is this? It would be good to know for pros and cons.
    I made some cuts with a fretsaw, roughly sawed along the line, then rasped it and sanded it into shape.
    This is how it ended up - though I did refine the shape later on
    @discoStu - It's KitBuiltGuitars.co.uk
    Pros would be it was well packaged, seems well tooled and sanded to a decent standard.
    Cons -
    - machine heads look crap and innappropriate,
    - tiny pots that will go in the bin -
    - pickups: who knows, but I don't have high hopes. I'm tempted to save myself time and discard them without installing - just buy some IG Blues Engines or similar (can't stretch to Oil City despite loving the Stone Tones in my Strat!)
    - Not really "cons" at this price point but 3 pieces of mahogany in the neck, and 4 in the body (plus thin maple veneer over the mahogany top)
    The biggest con, which I've only just realised, is how much smaller it is than a proper LP. Glued together it stand about 1.5" shorter than the real thing, despite having the correct scale length. This means the (SPOILERS) Bigsby B7 will hang off the end.
    Here's the body and neck. I'd just given it a rub down with lighter fuel prior to grain filling
    I used a mahogany tinted grain filler. Here's the body after I'd sanded it back.
    TOP TIP: Make sure you scrape as much of this off as possible before it dries, as it sets hard (as indeed it ought!)
    I used water based dyes to get the mahogany most of the way there colour-wise. In the past I've found it took too much cherry lacquer to get the depth of colour I like, so I gave it a head start with the dyes - red and black, mixing and sanding till I liked the colour.
    The top has a nice figure, though kind of 'shallow' looking
    Scary dark stain!!!!
    Went a bit too dark and deep with the brown/black dye, really. I had to sand it back quite hard. I stopped when I could feel myself going throughthe veneer at the edges. Ideally I would have liked to get it back a bit lighter.
    TOP TIP: don't go too deep and dark with your stain in the quest for stripes!
    Using yellow, red and brown dyes, I went for a sort of dark unburst.
    Quick mock-up before gluing:
    ...and gluing. I used Titebond Hide Glue, just because a quick google reveals that that's what everyone uses!
    Few coats of red gloss lacquer
    And a few coats of gloss clear coat - this is all from nitro rattle cans btw.
    Now the hardest task of all: Leave the damn thing alone for a couple of weeks...
  • paulnb57paulnb57 Frets: 3073
    Good effort, that looks great!
  • JalapenoJalapeno Frets: 6399
    Superb !
    Feedback
  • SteveRobinsonSteveRobinson Frets: 7079
    Yes the clear lacquer has really made the colour stand out on the top, it looks great!
