Xotic Ep booster
I currently use my TC spark boost first in my chain as an always on pedal as i find it sounds a lot fuller and seems more 3-dimensional.
Ive read a bit about the Xotic Ep booster, and wondered if its worth the extra £'s.
Does it really add more to your tone than other boosts?
I know that boosts are pretty simple circuits, so what makes the Xotic so special?
  • thermionicthermionic Frets: 9671
    Association with Echoplex users. Although I understand the circuitry is not derived from an Echoplex at all, just a one-transistor amplifier like all these magic boosts.
    Go on Ebay and get the cloned version for £18. XP booster....brilliant lil pedal for buttons. SP = Super Pricey. innit.
  • ricorico Frets: 1220
    I'm using the SP compressor wound up fully (max volume, zero blend) before an OCD with mild gain and it sounds marvellous.
  • Cool..im talking about the EP booster.
  • WazmeisterWazmeister Frets: 9608
    It's successful for a reason, the EP... it just adds a little 'something' t your sound, a bit of warmth... ive never really used it as a boots, more as an always on.
  • Danny1969Danny1969 Frets: 10455
    The EP is a well built quality pedal but jeese ....  £100 plus for a simple transistor boost in a nice box !!!
    treble boosters are a similar story for what they are.
  • starwarsnosebleedstarwarsnosebleed Frets: 2357
    edited January 2017
    But does it add something that the TC spark (or other boosts) doesnt? I would be using it as an 'always on' too.
    I have seen that XP being A/B tested with the Xotic EP on Youtube. It has the internal dip switches and everything. I couldnt tell them apart.
    But it makes you curious about the hype the Xotic gets.
  • english_bobenglish_bob Frets: 5164
    edited January 2017
    It's much cheaper to pay Chinese wages to make a copy of someone else's circuit than it is to pay American wages to build a circuit you designed yourself (even if you did base it on something else).
    I've got an XP booster- I just needed a cheap way to boost my volume at a couple of points in my band's set, so I haven't really explored the "betterizer" potential of the pedal, just the "louderizer" properties. It does that job just fine.
  • JalapenoJalapeno Frets: 6398
    There's plenty 2nd hand on Ebay.  First pedal on any board for me.
    Feedback
