Delay -> Phaser or Phaser -> Delay?
HAL9000HAL9000 Frets: 10061
As per the title...
I know it's going to be try it and see, but is there a 'normal' way round for this?
  • JezWyndJezWynd Frets: 6307
    Phaser first.
    But now you've mentioned it I must try the reverse.
  • The conventional way is phaser first, but I bet the other way would sound really cool, now I think about it...
    update: Phase after delay does sound good, it dulls the attack of the repeats (DD-7) and makes the wave of the phase more apparent. I prefer Phase first though for everyday use.
  • juansolojuansolo Frets: 1777
    Definitely depends. I've done it both ways (missus), and actually prefer phasing the delay rather than delaying the phaser.
  • ICBMICBM Frets: 74281
    I prefer phased delay to delayed phase because the phasing sweep continues on the repeats. I use a phaser more for the slower airy swirly sound rather than the faster watery bubbly sound. I must try it the other way round with the faster phasing though...
  • DesVegasDesVegas Frets: 4712
    I do like a phaser after delay. Tremolo after flanger is where I'm at right now
    Funnily enough, I prefer modulation before delay because it breaks up the sweep more. I like the tonal changes and the sense of movement you get from having a flanger or a phaser on but not the constant swoosh noise, so modulations go pre-dirt (although generally not much dirt) and pre-delay for me.
    But yeah, both are valid. I've just finished wiring up an order switcher pedal so I can run my M5 either in front of my amp / dirt pedals or after my delay in the effects loop and it's fun playing around with different effects in each position.
  • DopesickDopesick Frets: 1510
    Call me stupid but...after all this time I'm still confused about what is meant by 'after' and what is 'before'.
    So if the chain is amp <-- phaser <-- delay <-- distortion <-- guitar - would this make the phaser after or before? This is how I usually use it. The other way it kinda buries my DD7 (kinda like what JezWynd alluded to).
    edited February 2017
    @Dopesick ;;;
    after means amp side / output .. before means nearest the guitar / input
    so your phaser is after your delay
    Aha that's what I thought.
    To my way of thinking that's a backwards way of writing it. Your signal starts with you hitting a note so it's guitar-distortion-delay-phaser-amp surely?
    Yep. Tone comes from the fingers, so that's where the journey begins.
    I just wrote it out the same direction visually as I see it on my board, but yeah you're right.
  • Delay at the front, everything else after :-D
