New Project - Part 1 Completed
13»
    Yeah I'm not sure I will go for a Teisco copy..
    The plate is an interesting idea, but getting the shape right on a Tele style head will be hard..
    Rox said:
    Yeah. That looks pretty hideous.
  • RoxRox Frets: 2147
    It's got Country & Western bling written all over it...
    Ah, both types of music then!
  • WezVWezV Frets: 16750
    edited March 2017
    Rocker said:
    @WezV, that Teisco looks awful. And I presume the front strap button is in a similar position as on an SG
    You both have terrible taste, the teisco is a work of art    (I used to own the bass version)
    Anyway, it was the concept I was referring too, not the actual style
    Rox said:
    That does look hideous, but many makers use an inset plate on a headstock which is a similar idea, and it can work well with fender shapes.  I quite like the trussart solution but it doesn't quite work near the headstock curve.  I think it would work better with a bit of the teisco shape at the nut end.  I like the teisco version because it doesn't follow the headstock shape
  • valevale Frets: 1052
    edited March 2017
    @vale is Surf Green 60s pop enough for you?
    me & andy find your particular shade of green to be entirely pop-appropriate.
    https://s-media-cache-ak0.pinimg.com/736x/55/4c/22/554c22a53ca886c889ca78ee146f6307.jpg
    please continue.
    hofner hussie & hayman harpie. what she said...
    @vale - I am glad! It's certainly a bright colour - difficult to spray, but looks pretty good now!
  • EvilmagsEvilmags Frets: 5158
    The question for any Fender guitar paint is ·would it look good on a hot rodded classic american car. (pre 1965). That is hitting that spot.
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8824
    Looks good! I'll be spraying a tele in surf green next week, can't wait!
    Well, Part 1 of the build is done.
    Body and neck finished and now united with each other.
    Machine heads installed.
    Bridge installed.
    Pup and electronics installed.
    Strings on and setup performed.
    Doesn't look too bad:
    I need to do some daylight shots tomorrow to show off that proper Surf Green goodness..
    And then, it's pick guard time. Will be much fun. Once I have a spare, it's time to decoupage!
    How does it sound, you say?
    Thumpy. Really really thumpy. Like, more thump than I've heard before. It's very different to a split-coil P, and quite unique. But I like it. Yes, I like it.
  • sawyersawyer Frets: 732
    Looks cool man!
  • GSPBASSESGSPBASSES Frets: 2351
    The pick guard is not standard, I can send you a jig if you want to make one your self.
    That looks sooooo good :)     I actually think the pickguard is spot on for it - it emphasises the surf green and doesn't detract from it as many pickguards do.
    Superb job :)
  • RockerRocker Frets: 4991
    Superb job :)
    Agree 100%. Knowing when to put the brush away is the mark of a great painter...
    Nil Satis Nisi Optimum
    Well, I think you might be right.
    I'll leave it as it is for now. It's satisfyingly 60's enough for now!
    Here's a daylight shot to round it off:
    Yup - looking at it again, that's class :)
