I think part of the problem with linux is that there is no one who owns the overall user experience and as such you get a few unfortunate effects.
1.) No design contract between components means that it isn't always obvious which component is the problem (and therefore who should be fixing it...if they can even be bothered since its mostly staffed by volunteers or corporate sponsorship which has its own priorities).
2.) Community support is somewhat cargo-cultish meaning that when you go looking for help you almost never actually diagnose root cause and then work out how to fix it, instead you just try copy/pasting what other people have said worked for issues with similar symptoms. since no one else bothered to diagnose root cause either and 99% of linux users dont understand the internals (including myself) the quality of advice is variable to say the least.
Of course this distributed nature also provide some of linux benefits like many-eyes and the one tool per function philosophy but I'd say for someone who just wants a desktop OS that works without needing to regularly dive into the documentation for effectively a hundred disparate products it isn't there yet.
FWIW the main reason I use linux at work is actually not due to the OS itself its just that for windows users the company mandates a metric ton of crapware is installed whereas for linux the requirements are much lighter.
Its everywhere
The BBC made extensive use of Linux for broadcast video playout systems. They developed a system called Raven which used Linux plus other open source components. Controversially they didn't make their source code publicly available which technically breaches GPL terms.
