TRADED Fender Super Sonic 60 112
Van_HaydenVan_Hayden Frets: 437
edited June 2017 in Amps £
https://i.imgur.com/S9X22tu.jpg
Fender Super Sonic 60w.
Just rebuilt, new board set, fresh set of JJs tubes. Stock faults (like +/-16v supply)fixed & wont cause issue.
Also fitted a rather nice brand new Creamback G12-H 75.
£600 or trades
or £550 with an eminence speaker
  • ChéChé Frets: 305
    What's the fault with the voltage? I had a 22 that I loved but it was too noisy to record with.
    What kind of trades?
  • Van_HaydenVan_Hayden Frets: 437
    @ché not sure about the 22 but the 60 has a couple of zener diodes and ceramic resistors that get very hot on the PCB, with a high voltage  screen supply running underneath. They're a touch noisy - the trick to recording noisy amps is turn up loud, then the signal to noise ratio improves & when the guitar is in the mix the noise isn't an issue. This is most true of amps like some fenders where the volume is early in the circuit. A good test of any amp is turn the master up full and control the volume from the gain, then you realise just how bad many amps are!
    @richardj I'm not sure....I don't want/need anything but always interested in nice stuff!
    Bump!
    Open to offers - don't be shy!
  • shaunmshaunm Frets: 1633
    edited June 2017
    Hi Hayden.
    Would a 1983 JCM800 be of any interest? I should mention that I mean a 4010 2204 model. It is the vertical input version (don't know why but that seems to make a difference on the gear page).
    I might be - got a soft spot for old JCMs! Where are you?
    Hayden, I'm in Huddersfield
    Dropped you a PM
