Single favourite effect?
  • frank1985frank1985 Frets: 523
    edited April 2017
    saturation
  • dindudedindude Frets: 8540
    I'm late to this thread and sorry for repeating what others have said:
    Delay
  • revsorgrevsorg Frets: 885
    EVH Phase 90 set at 9 O'clock and the little grey button pressed in the way that sounds right.
  • dogloaddogload Frets: 1495
    It would have to be delay.
    I can spend hours just noodling with delays and I reckon they get more hours of use than any of my other effects. My El Capistan is virtually always on.
  • TheBlueWolfTheBlueWolf Frets: 1536
    Love a decent reverb but my favourite is overdrive.
    Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
  • VoxmanVoxman Frets: 4727
    edited April 2017
    Misread this first time round and interpreted as 'essential' effects. As far as favourite effect goes, I'd have to go with an EQ pedal and/or BBE Sonic Stomp Maximiser.  Individually (& even better together) these can change/shape your underlying tone, and add punch to cut through the mix, in a way that nothing else can.
    If you are struggling to get your tone quite 'right', before spending a small fortune on pick-up and/or speaker changes, try a cheap 7-band analogue EQ and/or BBESSM - these might be all you need to crack your tone problem, and can be used with any of your guitars or amps!
  • I would go with the particle reverb on the zoom cdr
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • ChuffolaChuffola Frets: 2026
    I'd pick reverb but I'm genuinely curious about the love for chorus. With very few exceptions (as in actual recorded examples), I think its my least favourite modulation. When I use it I just sound like a bad 80s tribute band.
    Only when I'm playing Cure or Cocteaus stuff.
  • KKJaleKKJale Frets: 982
    edited April 2017
    The second-best sound I ever got was in about 1983, when I switched on my new Boss chorus.
    The best sound I ever got was in 1987, when I switched it off...
    (Badum-tish, I'm here all week).
  • mike_lmike_l Frets: 5700
    In some semblance of order.
    Phase
     Delay
    Chorus
    Wah.
    I'm not counting dirt.
  • Usually Reverb is my favourite, but currently it's a Granular Delay (Red Panda Particle)
  • saint_iveysaint_ivey Frets: 17
    edited April 2017
    I'd have to go for a Leslie Simulator. A good one is a truly inspirational sound and really makes me smile when playing.
    I love many others but if pushed; you can get drive sounds by cranking your amp/guitar, reverb occurs naturally in the space you play and delay is great but not really inspirational.
  • HAL9000HAL9000 Frets: 9740
    Phaser. I love that slightly swirly sound. Think Tom Petty's Learning to Fly. IMHO a phaser, subtly used, really helps to fill out the sound.
    I don't use a lot of gain and find all I get all the 'grit' I need from the amp.
    The effect I detest above all others is chorus. The horrible out-of-tune-ness is akin to scraping fingernails across a blackboard.
  • Analogue Octave Down.
    But I use delay most!
  • All day long - delay.
    I got a Particle again recently, it's just brilliant. Instant weirdness. I stack it in Dens mode in front of a long tape delay (with a lot of repeats) and before a big plate reverb, and it sounds huge.
  • Overdrive
    Delay.
  • A cookin amp and the guitars volume pots....
