are you a high/medium/low action person
13»
  • EdGripEdGrip Frets: 736
    I think there is a little bit of a value judgement attached to low action. My action's lower than your action, ner, kind of thing.
  • 'Medium'. Honestly I usually set up according to manufacturers specs and then do the final tweaks by feel.
  • LixartoLixarto Frets: 1618
    High enough to be able to play slide.
  • ICBMICBM Frets: 72954
    I thought it was the other way round - a higher action was more 'manly' or the sign of a 'real player'. At least when everyone seemed to want to be SRV...
    On that basis J. Mascis looks like the best player ever :).
    I actually can't quite believe he does have it that high, it's surprising he can get the intonation even close - and yes, I have heard him play ;).
  • streethawkstreethawk Frets: 1633
    He's a strange fella. Never plays a Jazzmaster - or through marshalls - in the studio and get s a bit testy when people ask about that.
    I read a long time ago that he likes his action high because he likes the guitar to fight back, which sounds laudable. I suspect he's created a musical badass persona and it pays. Bit like a WWF wrester.
  • GruGru Frets: 339
    Apart from an actual reference, whether it be a penny or a measurement, it's hard to know what a low/medium/high action really is. My low may be someone else's high.
    I like the idea of seeing whether your fingers slip under or over the strings when bending. It would certainly give a good starting point and we all have different size fingers.
    My Pacifica always tended to slip under my fingers, but at the time I didn't know much about setting action height, I just set it as low as possible, without buzz.
    What us the advantage of setting the action higher for chords?
  • jaygtrjaygtr Frets: 218
    I like my les Paul nice a low, but my tele a tad higher. As it suits what I tend to play on them.
    I would add that I prefer it slightly higher than I used too as playing speed is less of an issue these days.
  • Adam_MDAdam_MD Frets: 3420
    My action went up after I learned to setup my own guitars. The guy who used to do my Setups had a rep in N Ireland of being the best so I never questioned how low my action was, I thought it was supposed to be like that. I've been much happier since I started doing my own, the Dan Erlewine books I picked up a few years ago have been priceless.
    Muting/damping unwanted notes, for me.
  • 57Deluxe57Deluxe Frets: 7350
    ..I'd be happy with ANY actiion...!
    <Vintage BOSS Upgrades>
  • J Mascis's action is pretty low compared to Freddie Green's.  See video.
    http://www.dailymotion.com/video/x1rh8s_travlin-light-diane-schuur-freddie_music
    Medium height for me.  I use 10-46 strings and, with capo on the first fret, top E is usually around 1.5mm and bottom E 1.8 - 2.00mm at the 12th
  • fretfinderfretfinder Frets: 5101
    Why put a capo on to measure the action??
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
  • Why put a capo on to measure the action??
    It's the correct way to do it as it takes the nut out of the equation.
  • bertiebertie Frets: 13577
    edited January 2014
    hmm not really -   gives a false reading for the true action, unless you're playing with a capo on all the time.
    Not all nuts are equal - You want the nut IN the equation
    Its "half way" to the correct way to measure neck relief
    Some people do and some people don't. Most of the time I am setting up the action for myself and so it is relative heights I am after. It takes one variable out. I always check and adjust nut height too
    edited January 2014
    which is fine,  but if you're using a set measurement, rather than "feel" surely you could set two guitars up with the same measurement at the 12th,  take the capo off and they could be quite a bit different.
    each to his own tho, as you say
  • SkippedSkipped Frets: 2371
    I first heard people obsessing about crazy low action at about the time when people were looking at Alvin Lee or Tony Iommi and saying:
    "Wait a minute......there are more notes there than there are pick strokes. Huh??"   :-O
    Up to that point we thought that a pull off was something that happened in a dark corner of the cinema.
    I would say it's the incorrect way to do it - you need to get the nut height right first, and then the relief, before even trying to check the action.
    Holeeshit!
