Which Jet City...
  • newi123newi123 Frets: 887
    CHrisP86 said:
    So ended up on a slight detour as I won a Soldano Astroverb on eBay last night. Looking forward to picking it up!
    Awesome! Looked at that myself - what did it go for in the end?
    pls report back on it, and drop me a pm if you don't like it!
  • CHrisP86CHrisP86 Frets: 360
    No one else bid so I got it for £450. Mad price really!
    Might be getting it this evening and will report back.
    Picked the Astroverb up!
    Only really got a couple of minutes to play through it.  Think it will really suit me though.  Will do a proper NAD page next week when I've had a chance to play it at a rehearsal.
    One concern is that it came with a little 1x12 cab (not the Soldano one) that says it's rated at 4ohms.
    The astroverb is designed for a 16ohm load so I hope this hasn't caused any damage!
  • digitalscreamdigitalscream Frets: 26742
    It may well have a different speaker in it from the one that was apparently 4 ohm. If you can't be bothered taking the back off (or the speaker doesn't say), just get a multimeter and test the resistance across the tip/sleeve of a jack plugged into it. It won't be exact, but if it's a 16 ohm speaker then it'll probably test somewhere between 12 and 15.
    <space for hire>
