Looking for cheap dual overdrive and boost for Marshall sounds, any ideas ??
  • professorbenprofessorben Frets: 5105
    Depending on budget,
    Boss Ls-2
    with a Sd-1 on one loop and a DS1 on the other.
    Failsafe.
    Cheap (ish)
    replaceable anywhere in the world
    Easy to sell when you finish with it.
  • VoxmanVoxman Frets: 4727
    A Marshall Guvnor 2 and a Marshall Bluesbreaker 2 pushed really close together
    Tried that combination...its pretty decent if you set the BB2 to boost. But I preferred Guvnr2 with a tubescreamer after it.
  • SassafrasSassafras Frets: 30306
    AMT preamps offer a good choice of amp styles for a sensible amount of money.
    Ooooh those new Mooer Preamp pedals, got speaker sims too.
  • riffpowersriffpowers Frets: 344
    Boss Ls-2
    Failsafe.
    Cheap (ish)
    That'll work!!
    Boss Ls-2
    Failsafe.
    Cheap (ish)
    That'll work!!
    It's what I used to use into my old800.
    The benefit of the LS-2 is that you can get A+B loops mixed
    or
    A -B -Bypass to give s pseudo 3 channel rig.
  • ragingbenragingben Frets: 107
    I'd look into Amptweaker Tight Drive pro or big Rock pro. I own the drive and it's a truly versatile pedal that you can tweak to sound great into pretty much anything. Built like a tank too. The pro version has the boost too, I reckon the big rock would be the one.
