SOLD: Gallien Krueger NEO-II 112 Bass Cab (£180)
KebabkidKebabkid Frets: 3318
edited July 2017 in Basses £
As the title says. Up for sale and no trades
Specifications
·         Power: 300 Watt (8 Ohm)
·         Speakers: Neodymium 1x12
·         Weight: 35 lbs
Tough vinyl covering, steel grills, plywood construction and GK side mounted flip grip handles make for road worthy durability and easy loading.
A variable horn attenuator for optimum control of horn level when in full range plus switch for Bi-Amp operation. One professional twist lock speaker connector for no compromise performance and one common 1/4 inch input.
Special Neo driver with 2.5" edge wound aluminum voice coil designed just for this cabinet, manufactured in the GK USA factory.
Internal bracing to insure tone robbing leakage of sound through the walls of the cabinet is minimized. Plywood construction ensures a rugged light weight cabinet, ready for the road. Critically tuned ports ensure optimum performance while coupled to the cabinets specifically designed speaker.
Good condition, a few minor, surface scuffs to corner plastic protectors and a little on the vinyl but no rips nor does it have a cover
I'm looking for £195 £180 PPG on this and these are £400 new.
Forever battling with Photoucket and my account, so stock images shown in link but will endeavour via another platform to get some actual photos up or PM me and I can email them
Succeeded with imgur
http://kebabkid.imgur.com/all/
https://www.andertons.co.uk/p/301-0340-B/bass-cabs/gallien-krueger-112-neo-ii-bass-cab?LGWCODE=3010340B;56375;6335&gclid=CJ3hi5OP3dMCFUOZGwodtnUNmA
I'm not posting this one as I don't have any packaging so collection preferred from Wallington, Surrey or can deliver within a reasonable distance (20-30 miles for petrol)
I work up in central London (King's Cross) so given it's reasonable weight, I might be able to bring it in and meet you there.
Thanks
