Specifications
· Power: 300 Watt (8 Ohm)
· Speakers: Neodymium 1x12
· Weight: 35 lbs
Tough vinyl covering, steel grills, plywood construction and GK side mounted flip grip handles make for road worthy durability and easy loading.
A variable horn attenuator for optimum control of horn level when in full range plus switch for Bi-Amp operation. One professional twist lock speaker connector for no compromise performance and one common 1/4 inch input.
Special Neo driver with 2.5" edge wound aluminum voice coil designed just for this cabinet, manufactured in the GK USA factory.
Internal bracing to insure tone robbing leakage of sound through the walls of the cabinet is minimized. Plywood construction ensures a rugged light weight cabinet, ready for the road. Critically tuned ports ensure optimum performance while coupled to the cabinets specifically designed speaker.
