Any garden machinery powered by Tea and Cake is infinitely superior to that powered by dead dinosaurs!
Terrible mess if the chain comes off !
He can probably juggle them like cirque de soleil
Either that or he has a leather mask somewhere hidden in the truck
Also have an old MS025 which is basically an older MS250, that's a good workhorse too.
I like Stihl because the parts like carbs etc are readily available as are generic piston and pots. If you get a used one that doesn't have crank case or crank seal issues it will last a long time. I'd avoid the cheaper Stihl's like the MS170 and cheaper Husqvarnas though.
Also loads of fake saws about, fairly obviously fake and the newest Stihl versions are MS 251 and MS 261.
Depends what you want it for, an old MS025 that still works good would do you.
Oh and always wear face protection and a helmet and don't cut with your body over the line of the blade, when you experience a bit of kick back at full revs you'll know why, but I think they're generally safer than circular saws.
Personally I'd go for one of the bigger names for ease of use and reliability. 14" is big enough for pruning and firewood, and will tackle trunks with a larger diameter. The longer saws are harder use because of the weight. Personally I prefer petrol to electric. You don't have to worry about cutting the cable, trapping it under cut logs, or tripping over it. You can also use a petrol saw at the other end of the garden, or anywhere else where there isn't any electricity.
FWIW mines a 14" Stihl.
Even the groundworks people I use don't like chainsaws - they subby chainsaw work out to a tree surgeon. He clearly knows what he's doing with it, dresses like he's in The Hurt Locker and acts like he's using an underfed tiger full of explosives. I trust him with a chainsaw.
https://www.amazon.co.uk/OREGON-Chainsaw-Clothing-Universal-Leggings/dp/B0151S4948/ref=sr_1_3?ie=UTF8&qid=1495213072&sr=8-3&keywords=chainsaw+chaps
I'm sorry, I can't help you with make and model I'm afraid.
Literally, a few passes of some 5" branches and it's back to the shed to be sharpened again - I'm led to believe that the chain is a decent one (Oregon).... any ideas?
http://channel.nationalgeographic.com/life-below-zero/videos/deleted-scene-glenns-new-timber-saw/
However if you don't have the cash or don't want second hand, I'd also recommend Echo. Father in law bought one new and I used it to reduce a mixed hedge (laurel, hawthorn, holly etc). Seems to be a decent quality saw, maybe not as rugged as a Stihl but for the price, it'll last for what you want it for.
And do make sure the tension on the chain is just right. I've seen too many people using chainsaws with the chain nearly dangling.
