FT - Bad Cat Black Cat 30r Combo
HoraceBHoraceB Frets: 337
edited July 2017 in Amps £
Due to a bad back and age the combo is getting a bit heavy for me.
So, does anyone fancy trading a Bad Cat Black/Hot Cat 30r head (and cab if poss) for a 2014 Bad Cat Black Cat 30r Combo? Poss financial adjustments if necessary. I would consider other decent heads and cabs, (Freidman, Bogner etc) with two channels but the Bad Cats are my preferred choice.
Cheers.
  • DominicDominic Frets: 16199
    Or Bad Cat + Bad Back = Bad Luck !
  • ToneControlToneControl Frets: 12016
    edited May 2017
    HoraceB said:
    Very long shot.
    So, does anyone fancy trading a Bad Cat Black Cat 30r head (and cab if poss) for a Bad Cat Black Cat 30r Combo? Poss financial adjustments if necessary. I would consider other decent heads (and cabs) but the Bad Cats are my preferred choice
    You could say that Bad Cat & Bad Back not the best combo for me atm!
    Cheers.
    why not just have a cab made for it? you could use a very light cab for the amp tray, perhaps even Aluminium or plastic
    get a speaker cab and move the speakers over - again you can go much lighter - look at the Victoria Twin tweed - the whole 2x12 combo is lighter than most 2x12 speaker cabs
    btw@ Matchless used to sell branded head cabs to Combo owners, I have no idea if badcat ever did this
  • HoraceBHoraceB Frets: 337
    @ToneControl cheers for that. I will investigate further. Cool idea about the branded cabs, I'll write to Bad Cat.
    you can run an amp head with no cab at all, just bolt a piece of wood or plastic or metal across the tray, and stand it upside down on rubber feet you can buy for £1 each, I used to run an old  valve hi fi amp this way
    Put it in a light weight box with plenty of padding to transport it
    I take my DC30 and similar amps to be fixed this way, I don't take the whole combo
    Make sure you don't touch a capacitor!!
  • IvisonGuitarsIvisonGuitars Frets: 6842
    I made a head shell and cab out of my Black Cat Combo....
    From this:
    To this:
    Made it SO much easier to do pub/club gigs. I made the cab so the baffle and speakers from the combo slotted straight in so there was no messing around making a whole new baffle/grill cloth.
    I'm actually converting it back to the 2x12 combo this week for some in/out festival gigs we have next weekend. I'll let you know how my back feels  - mines flight cased too so it's DEFINITELY a 2 man lift - and i'f I'm feeling strong, I may consider moving these shells.
    http://www.ivisonguitars.com
    (formerly miserneil)
    @ToneControl I think I'd be scared to got to gigs like that :) @miserneil That's really very impressive work, I'm not sure my woodworking skill would quite meet the challenge. Thanks for the suggestions chaps, definitely food for thought.
  • kramereekrameree Frets: 101
    Pm'd
    Back-strain Bump.
