This really looks like a cracking bit of kit - if the delays and reverbs have spillover between patches, it might be the basis of a new preamp board for me; an AMT preamp in each loop for three "channels", effects from the Boss, job done.
I'm interested to know which particular algorithms are at play here. Like are the Reverbs from the RV-6?
Website || Feedback Thread || PayPal
That look awesome!!!!
literally what I expected Line 6 to be putting out to replace the M series.
is there a release date? this may have shaken up my little/backup board plans!
I can see how it would be a good choice for someone who wanted a compact pedalboard but didn't want to be limited to only a few effects and was more picky about some of those effects than others.
Manual and various other stuff is on the BOSS website. I skimmed it- it doesn't seem to have the same routing flexibility as the ES-5/8, but it does have the same assign and internal pedal functions as the DD-500, which makes for a lot of interesting possibilities.
In typical BOSS fashion it doesn't look all that exciting to start with, but as you start to dig in to the possibilities it gets much more interesting.
https://static.roland.com/assets/media/pdf/MS-3_Parameter_Guide_eng01_W.pdf
When you edit a post for some reason it breaks the YT links
Tap tempo with the delays will no doubt be squirrely and pitchy and they'll never fix it.
is it the same algos as GT-100 then ?
Trading feedback here
