Comes with a 30 minute warranty.
I will admit I don't quite understand all the hate for the sound - they're not *that* bad, although I seem to have accidentally improved mine while trying a slightly unorthodox method of fixing one of the usual problems - but really they're no worse than any other modern Marshall. The orange 'crunch' channel in particular can sound really pretty good.
It's the build quality that's the issue for me. They simply have far too many serious design faults to be properly reliable in the long term, although it's true that many do seem to work well enough for quite a long time. Even after Marshall re-designed the main PCB twice, there are still other problems - some of them really stupid, like a fail-unsafe bias adjustment scheme, and running the whole speaker current through a switch in a jack, which can only be the result of design by people who don't know enough about valve amps to spot the potential failure modes - that were entirely obvious to me from the start. Which is quite concerning given that Marshall have been making amps for longer than I've been alive.
I still think I'll end up scrapping this one for the parts - I just don't have enough confidence in it to sell it to anyone with a clear conscience, even if I find what's still causing the hum/loss of volume problem on the clean channel after it's been on for half an hour. Currently I'm using it (it's the combo) as my workshop speaker cabinet...
It'd be a shame to scrap it.
I tried a tsl 100 half stack against a jcm900 slx (very different amp, I know) into the same cab and the slx absolutely destroyed it.
Obviously it's a single channel amp, but it really was a huge difference. The tsl just sounded buzzy and fizzy, no matter what I did. I didn't try cleans as, at the time, I was into The Most Brutal Stuff(tm).
The slx was high gain, and had a bit of top end fizz, but it's needed to some extent I think. I've never tried a tsl since, such was my dislike for it.
I don't mean binning it either - everything in it from the cabinet down to the knobs will be kept and re-used.
Yes, I agree. When the 900 series came out I was appalled at how bad they were compared to the 800s and older Marshalls, but everything they've brought out since has increased my appreciation of them
I have a friend who owns a lot of Marshalls, most of the versions from JMP up to a JVM Satriani model, and his favourite is actually the JCM900 Dual Reverb. (Despite it being notoriously a hybrid amp!)
I think the TSL was the last hurrah (if you can call it that!) of Steve Grindrod, who designed the Vox Custom Classic range, etc., shortly thereafter. He had been at Marshall since the 1970s and was in charge of design of the JCM800s, Jubilee, JCM900s, etc. I think he’s responsible for the Club and Country, too.
He started Albion Amps after leaving Korg/Vox. Haven’t heard anything about those in some time…
Yeah, I don't mind the mg range. They're perfectly decent for practice and the big one can do some pretty cool sounds.
The huge mode 4 sounded okay too, but had a tendency to asplode. The cabs were good though.
I have seen the schematics, and it appears that Marshall have learned not to repeat the mistakes of the dreadful MG-DFX series and the AVTs and Mode Fours, with their fan-cooled IC power modules, which are absolutely notorious for failing - the new series use discrete transistors. I can't remember how many MG100DFXs (the most commonly failing model) I've fitted aftermarket power sections to or simply turned away when the owner doesn't like the repair estimate. I will not replace the power module with the factory one, there's a high chance it will come back and I have to replace it again for free. (And I won't work on a Mode Four, ever, for any reason - too risky.)
I'll admit the MG100DFX can sound quite decent if set up right though.
