I think my main pc might be on its last legs, another inaccesible boot device error, last time i needed a reinstall to get rid of it. COuld jsut be a disk but the disk is only 18 months old. I bought it in Jan 2010 so its done alright and has been creaking a bit anyway.
So PC types whats the current budget for I guess what most peoplle would call a mid range machine. Needs are in priortiy:
Running reaper - 16 channel simultaneous recording with 4-8 channels of low latency ampsim vsts running live.
Quiet
Ideally able to play total war warhammer, dawn of war 3 and elite dangerous, neither of which my current machine can do
Ive always gone for desktop in the past and am comfortable building as well as buying barebones / upgrading etc but this time round im wondering if i should jsut spend the extra to get a laptop so I can use it for mobile recording too,
Any thoughts?
ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
Not been over impressed by WIndows 10 reviews however so not sure to make the big plunge and upgrade.
Desktops aren't going for much these days, for my needs (internet, word processing, some recording software and a couple of other programs) I can probably get away with spending £350 approx.
For your needs though I'd expect it to be more though can't put an exact figure.
i5 CPU (and you can go second-hand and get something like a 4570, 6500 or new with a 7500) £100-£180
Motherboard appropriate £100-£200
8GB of suitable RAM £65-£100
GTX 1070 £370
PSU ~500W(ish) £75up
128GB SSD £60
1TB HDD £40
£800 ish...
Presumably you have case, and monitor...
Now, you can trim some fat here and there, maybe a suitable i3 CPU and a GTX 1060 ... no SSD. Maybe you have a power supply... but £600+ is what I'd want to think of budgeting.
The way 7 and 10 run software in the back is similar enough that it's not many programs that don't migrate 7-to-10
Might be an idea to check the developers forums to be sure though
(/recentapplefanboi)
Offset "(Emp) - a little heavy on the hyperbole."
Otherwise, it SHOULD still just work... ask on their forums if there's any issues when upgrading Windows - most likely you'll get a "nope it's fine" or "I had to do X, Y and Z to make it work, but after that it was fine"... and only need to worry if the answer is "Yes, lots of problems it doesn't work" .
I doubt you'll need to pay for a new version, unless there's a hinky terms of service
Obvs what you listed in terms of numbers above I probably don't need as high, but in terms of processor speed, RAM and such what would be the ballpark figures to run several apps with lag and such?
As for a minimum spec...
2 cores with Hyperthreading, or 4 cores without (so i3, or i5) and up... (anything over 6 cores will be wasted in gaming for now) running at 3.5Ghz and up (current gen chips in the i3 or i5 range will be around 4Ghz to 5Ghz so much whizziness)
8GB of RAM should be plenty (16 would future proof for gaming)
CPU and matching Motherboard expect to spend a minimum of £200 - unless you go second hand, which I did for my gaming PC... made some good savings (Though, since then I supplemented and added higher spec or newer bits).
I'd advise a lot of shopping around... as minimum baseline...
https://www.overclockers.co.uk/intel-core-i3-6100-3.70ghz-skylake-socket-lga1151-processor-retail-cp-590-in.html
https://www.overclockers.co.uk/asus-h110m-k-intel-h110-socket-1151-ddr4-micro-atx-motherboard-mb-684-as.html (can't overclock on that board... but it is cheaper than my initial estimate).
https://www.overclockers.co.uk/kingston-fury-red-8gb-1x8gb-ddr4-pc4-17000c14-2133mhz-single-channel-module-hx421c14fr2-8-my-26r-ks.html
£225.97 for CPU, Motherboard and RAM ... and there may be cheaper online shops.
Graphics-wise
https://www.overclockers.co.uk/sapphire-radeon-rx-570-pulse-itx-4096mb-gddr5-pci-express-graphics-card-gx-37u-sp.html (£199.99)
or
https://www.overclockers.co.uk/evga-geforce-gtx-1060-3072mb-gddr5-pci-express-graphics-card-gx-30d-ea.html
(£169.99)
And if you don't have an SSD laying aroung in your old computer
https://www.overclockers.co.uk/wd-green-120gb-2.5-sata-6gbps-solid-state-drive-wds120g1g0a-hd-53l-wd.html
(£52.99)
With something like that, you will need to knock a couple of screen settings down to a lower resolution, or not maximum texture details, but should be able to run the games you're looking at... the more you can spend the better things can be though. I'd aim to spend maybe £200 more on the graphics card and £60 more on the CPU and £100 more on the motherboard if you can... (or aim even higher, say say £1500+ for a really good gaming computers)
Bit rambly, but it's a Sunday afternoon and I'm watching telly
Spanner-in-the-works time - Ryzen AMD processors came out recently and they have similar pricing and similar speed (frame for frame in games pricing is very similar to Intel).. but for other computing duties the process-cycles-per-£ could be better than Intel by a reasonable range
It sounds all modernised now though, makes my current 3.20 Ghz Pentium dual core look outdated! I'm guessing my 3GB RAM isn't keeping up too well with numerous apps being open either. Even streaming videos can get stuttery sometimes but that might be YouTube or whatever.
I am looking at a few at the moment but will pay attention to the numbers, with so much choice out there it gets a bit confusing. But cheers for the recommendations!
That CPU/Mobo/RAM and the SSD should do you wonders
What's an SSD by the way and what does it do?
An SSD (solid state drive) is like computer memory and is made up of NAND logic gates so electrical impulses turn the 0s to 1s and vice versa. Only the speed-of-light-in-copper and the memory bandwidth of the connection limit the speed (and a couple of other factors...).
SSDs are MUCH faster for all sorts of purposes, and often one of the cheaper ways of speeding up a computer (swapping a spinning HDD for a non-spinning SSD)
Intel have divided their consumer stuff into:
Pentium G - low voltage desktop CPUs 2 physical cores
i3 - 2 physical cores with hyperthreading (basically a clever way of alternating processes to effectively double the number of processes running...)
i5 - 4 physical cores without hyperthreading (meaning it should be marginally faster for anything using all 4 cores... because it's not switching between processes, but it's more expensive to make as it's literally twice the silicon chips in one)
i7 - 4 (and up) physical cores with hyperthreading
i9 - new class which goes up to 18 cores with hyper threading and costs all the way up to $2000 for the top end model
A number of factors determine the "instructions per clock" count, ie the number of things the chip does in each of the (example_3.5Ghz cycles (3,500,000,000 hertz or cycles per second)... each generation Intel and AMD manage to increase this instructions-per-clock value, so the current 7th gen (Kaby Lake) is faster than the 6th generation even when both chips might have the same number of cores and running at 3.5Ghz (last generation change betwen 5% and 11% for intel and about 40% for AMD (though they were severely behind so it's not as crazy an achievement as it sounds)).
Both manufacturers are making some confusing naming choices lately so it can be slightly confusing... but the above is a good general rule of thumb
PC's have definitely come a long way since I first started buying them, don't understand what half the terminology is apart from the basic processing speed, and memory!
I could have spent less, but probably only £200ish, which never seemed enough to save to justify cheapskating the spec. I could more easily have spent more, but there was never enough value in the marginal extra processing power, or the top spec video card, to justify probably a 50% price hike.
So £1k has been my sweet spot.
I used to build, but nowadays just go for a prebuilt machine as there doesn't seem to be a massive saving in the DiY option, unless you're looking for a particularly oddball config that the assemblers don't cater for.
I have PCs for desk based work because they're far more tweakable and repairable. Also a lot easier to run a multi monitor set up, and don't have to worry about battery life / cycles.
For mobile recording, maybe consider an iPad - there's an incredible range of functional and cheap apps. You don't have to buy into the whole Apple world to use an iPad.
