Now sorted WTB 18v compressor
longshinslongshins Frets: 247
edited June 2017 in FX £
Hi there, I need a compressor pedal... ideally not massive, capable of running at 18v and bonus points if it has a dry blend control. Budget of £80ish
  • SporkySporky Frets: 28991
    18v? Why so much headroom when most guitar pickups put out 500mV max?
  • longshinslongshins Frets: 247
    edited June 2017
    I have an 18v outlet left on my ISO5 power supply, already daisy chaining off of the high current draw outlets. I know the Pigtronix stuff is ok at 18v, think there's an xvive compressor that is 18v. Can I turn the 18v outlet into a 9v with an adapter cable?
  • You'll be best with a Wampler Ego/mini Ego or an Xotic SP, both can run at 18V I believe (not selling my mini Ego though!)
    Check out my feedback thread here, would really appreciate it if you could leave a quick line if you've bought from me. :)
    Yeah the Xotic looks perfect...
  • carloscarlos Frets: 3511
    I can hear a difference between my philosopher's tone running at different voltages.
    I suppose where it is in the chain has a factor
  • -NFM--NFM- Frets: 10
    Ditto for the Xotic SP - imo its just a little 'tighter' at the higher voltage, but in a good way (very good pedal & its quite customisable too with the internal switches so I'd really recommend it!)
