SOLD: 240gb SSD - £45 Delivered
LooseMooseLooseMoose Frets: 918
edited July 2017 in Misc £
Good condition Kinston UV400 240Gb SSD. I've two of these removed from scrapped machines. Fully working.
£45 (each) Delivered.
  • spark240spark240 Frets: 2095
    Will it go in a Mac mini ?
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • LooseMooseLooseMoose Frets: 918
    Sure will! As long as it's one of the models you can actually take apart!
    its a late 2012 model, Im pretty sure it comes to bits as Ive looked into upgrading before.
    I dont mind doing the mechanical bit..its the software transfer stuff that puts me off....plus I want to add it to whats there now, not replace ...any advice?
    Mac Mini M1
  • beed84beed84 Frets: 2424
    Back up what you have on to an external drive, download Sierra or whatever OS install onto a memory stick, plug memory stick into Mac mini with new HD, boot from said memory stick, install OS, then use migration assistant to transfer stuff from back up  :)
    So will that put the OS on the SSD, and I keep everything else on the existing HD ?
    Mac Mini M1
  • Danny1969Danny1969 Frets: 10481
    You can clone the current drive to the new drive using disk utility then resize the partition if the old drive is smaller
    Mmm...the existing HD is 1 TB, ...
    Mac Mini M1
    Go clean install and buy a caddie for the old drive - transfer across at your leisure!
    P.s. one of these now sold pending the usual, one left :)
    PM,d
    Mac Mini M1
    And both gone :)
