Fender Princeton reverb Original or Reissue?
  • menamestommenamestom Frets: 4727
    Having tried a Sportsman I'd still go for a '65 if i was only playing at home or very small gigs.  I think the Sportsman loses some of the softness having a 12 inch speaker and stiffer power supply.  A moot point for me as I uprated the PT and swapped the speaker out in mine anyway, so a Sportsman could be better.  But if you want THE Princeton sound (if there even is one of those, many vintage amps have been modded), I think the reissue does agreat job.  The sound comes from 6V6's, fixed bias, short tail PI, modestly rated PT.   A speaker upgrade is still required, but not necessarily a modern stiff 100db job (like my ragin cajun).  Great for gigging, but essentially steers the Princeton formula away from it's origins.
  • zepp76zepp76 Frets: 2534
    edited July 2017
    Would an upgrade to a 12" speaker be a good or a bad thing? I would like volume without too much break up, that kind of Peter Green sound that is loud but not too distorted. I don't want it deafening loud but a bit of volume won't hurt!
    Tomorrow will be a good day.
  • richardhomerrichardhomer Frets: 24849
    edited July 2017
    I've never owned a Princeton - but compared the 65 PRRI with a 65 DRRI a few months ago.
    I was genuinely surprised how 'big' the Princeton sounded - it gave away little to the Deluxe in terms of volume - but had a sweeter core sound to my ears. I wasn't pushing either beyond 'edge of break-up' - though I was using a Strat, rather than a Les Paul.
    Whether either has enough headroom for gigging, I remain unconvinced (I haven't gigged for a long time - I hear stage volumes are much lower these days).
  • smigeonsmigeon Frets: 284
    Is that 'cos you're going deaf? :-)
    edited July 2017
    Yes
  • SassafrasSassafras Frets: 30306
    What?
    Depends, 10's sound different, some people prefer them.  But yeah for a PG sound I think you would need at least an efficient speaker and a 12" may be preferable.  Might keep humbuckers cleaner.  Ther 10" Ragin Cajun is a tough, efficient speaker however and holds together better than quite a few 12" inch speakers I've tried, so it is dependant on the actual models, not just the size.
  • robertyroberty Frets: 10894
    Hey how much louder would a Ragin' Cajun be than a Celestion Gold?  I have a PRRI '65 with a Gold in at the moment and there have been occasions where I could have done with a little extra volume.  I've ordered a tilt stand which will probably help more than a new speaker tbh
  • ICBMICBM Frets: 72602
    The Rajin' Cajun probably won't be as loud as a Gold. Eminence ratings are exaggerated by about 2-3dB compared to similar Celestions in my experience.
    I noticed no difference in volume between the Cajun and a 1x12" Gold I had in a separate cabinet....although it wasn't exactly a scientific test.
  • BluesyDaveBluesyDave Frets: 412
    edited July 2017
    I've had both in my 68 non reverb Princeton.  The Gold is a bit louder, but not massively.  The Ragin Cajun is a great 10 inch speaker, sounds much bigger than it should.  The Gold has gone, the RC is is in the Princeton.
    Should have said that my Gold was a 12".
    No Darling....I've had that ages.
